wasatchcars 0 Posted January 23, 2009 I have done this before but I must be doing something wrong now? In Inkscape I import a jpg bitmat trace delete top image then save as EPS. Opens up just fine in photo shop ( I dont have illy ) But when I import to SBE image can not be viewed? Click edit tab and there is the option to undo import so it is imported. Click cut screen opens without the warning contains bitmat ect. I have zoomed out all the way to try and find image with no luck? What am I doing wrong? Attached is a ESP I just did so you can see. drawing.eps drawing.eps Share this post Link to post Share on other sites
bk2design 1 Posted January 23, 2009 It opens as a raster/bitmap image not a vector Share this post Link to post Share on other sites
wasatchcars 0 Posted January 24, 2009 HMMMMMMM So what am I doing wrong? Some setting in Inkscape? Share this post Link to post Share on other sites
bk2design 1 Posted January 24, 2009 Are you opening it in photshop before you take it to SBE? If so that may be your problem. Share this post Link to post Share on other sites
wasatchcars 0 Posted January 24, 2009 I was taking it straight to SBE after Inkscape Only opened in PhotoShop to see if it opened after nothing in SBE Share this post Link to post Share on other sites
bk2design 1 Posted January 25, 2009 Did you delete the wrong layer in inkscape then? Share this post Link to post Share on other sites
wasatchcars 0 Posted January 25, 2009 You delete the TOP image right? Share this post Link to post Share on other sites
bk2design 1 Posted January 25, 2009 I just did one and the vector was on top. Share this post Link to post Share on other sites
quvmoh 1 Posted January 26, 2009 I am always forgetting what i am doing so have to double check. after tracing bitmap I move the top image down, you will notice while the moved image is selected inkscape states that it is the path "bottom panel in inkscape" and is the one you want to save, click the top image and the panel will change to image, you should delete this one. Share this post Link to post Share on other sites
