coateslr 0 Posted December 12, 2008 I have a Copam 4050. Is there any communication differences between using 25 pin parallel port to parallel and the 9 pin serial port to serial on the computer. I know the usb to serial causes several problems with the cutter stopping in the middle of cutting designs. Which one is better, the 25 pin parallel or 9 pin serial in keeping the communication between the computer and cutter optimized for better performance? Thanks Share this post Link to post Share on other sites
kenimes 42 Posted December 12, 2008 Either port is better than the USB for stability. I do not think one is better than the other, but I have had less trouble getting the 9-pin Serial port going on most computers. Share this post Link to post Share on other sites
coateslr 0 Posted December 12, 2008 Thanks Ken. I just received my new motherboard last night to replace the defective one. My husband installed it and I used an old windows 98 PC with a parallel port. So far I haven't had any problems with a blank display not showing the funtion settings since replacing the motherboard, and the cutter cut fine. I didn't want to take any chances of the USB to serial failing. Since the old PC is very slow, I need to purchase either the serial or parallel port to go on my faster PC. I was just wondering which one would work the best. Thanks a bunch for getting me up and running again. Share this post Link to post Share on other sites
kenimes 42 Posted December 12, 2008 Thanks Ken. I just received my new motherboard last night to replace the defective one. My husband installed it and I used an old windows 98 PC with a parallel port. So far I haven't had any problems with a blank display not showing the funtion settings since replacing the motherboard, and the cutter cut fine. I didn't want to take any chances of the USB to serial failing. Since the old PC is very slow, I need to purchase either the serial or parallel port to go on my faster PC. I was just wondering which one would work the best. Thanks a bunch for getting me up and running again. Anytime. Happy Holidays! Share this post Link to post Share on other sites
