wasatchcars 0 Posted December 7, 2008 Is there any instructions on how to create & cut 2 or more color graphics? Share this post Link to post Share on other sites
punkaroos 0 Posted December 7, 2008 if you use the search option on this forum, a lot of the members have posted many helpful tips. also, look in the video instruction section and there are several youtube videos that will show you. hope this helps Share this post Link to post Share on other sites
nbeaton 1 Posted December 7, 2008 I played around in SBE until I figured out how to cut multi colors. You outline the object and then go to Arrange on top tool bar,then click on Split Object then click off the object and click on the part you want to put color in. Go to the color chart on bottom and pick your color. Do this to all that you want different colors on your object. Then save it. Share this post Link to post Share on other sites
wasatchcars 0 Posted December 9, 2008 That explains it perfect. Thanks Now I have another question. I got the coloring down but now when I go to cut the registration marks are only on the original image. When I select one of the new colors it has no marks? How can I correct this? Share this post Link to post Share on other sites
cutme 5 Posted December 9, 2008 make your reg marks a different color than any other in your design, then in the cut screen select the color of the design you want to cut and then you hold down the control button select the color of the reg marks. do this for each color of vinyl. then do it like this guy does. bb Share this post Link to post Share on other sites
wasatchcars 0 Posted December 10, 2008 I got it now Thanks for all the help Share this post Link to post Share on other sites
