dave1510
Members-
Everything posted by dave1510
How do you install your printer profiles in Vinylmaster pro?
How do you delete sections of a curve in vinylmaster pro?
One thing that I would change on the Titan 2
dave1510 posted a topic in TITAN 2 Series Vinyl Cutter Discussions
One thing I would change on the Titan 2, are rather add to, is the number and spacing of the vinyl clamps. It only has 4. There is a roller for a fifth, but not a clamp for it. They should have six spread out, so you could use different size vinyl. -
Thanks!
How can you cut one file after another without going to the file, cut it, then having to go to another file and cut it, so on and so. Just setup your plotter and go.
How do you increase the space between tiles, when you increase the quantity to 2 or more. Thanks
When you go to cut, it gives you an option of the quantity you want to cut. How to do increase the space between the cuts. For example you chose to cut a quantity of 3, I want to increase the space between the 3 cuts. I have pro.
Anyone know a trick to get bubbles out of vinyl applied to aluminum?
What ended up doing is going to the contour cut mode, saving it as a pdf, then loading it into photoshop elements, then printing it out after adjusting image, then contour cutting it out on my titan, using vinylmaster. I know that's a run on sentence. sorry.
cobra ink pigment If I print out of Gimp or Inkscape it's fine.
Sorry I have an Epson 7110.
I have pro. It may not have RIP, but it has a print icon. The colors is off.
I'm trying to print an photo using contour cut wizard. I'm trying put my cut line into the boarder but it vectorizes the whole image. What I want is to put cutbox around the photo so I can adjust the cut-line.
I PRO. BUT I WANT TO PRINT THE BACKGROUND. JUST LIKE A PHOTO. A SQUARE.
How can you use a laser printer to print an ink transfers with white in the transfer?
I'll be cutting up a storm then all of a sudden when the blade gets close to the edge, the vinyl will bunch up. I don't think I have my rollers in the right position. I'm cutting HTV @ 400 with 90 pressure.
Deleting span between nodes and connecting nodes.
dave1510 posted a topic in VinylMaster CUT, LTR, PRO & DSR
How do you delete spans or lines between nodes, and how do you connect two different lines together? -
dave1510 replied to dave1510's topic in VinylMaster CUT, LTR, PRO & DSR
Still can't do it, but I did make a video> -
Titan 2
thank you
How do you pause a titan 2?
When I hit combine, the gap closes. -
Thanks for all your help! I still can't join nodes together. If I draw a polyline, go into node editing, and try an put the end of that line onto the end of another line, they do not connect.
