Days Won
2
Everything posted by MrMopar64
Am in in the ballpark, price wise, for vinyl shirts
MrMopar64 replied to Jive's topic in Business Practices, Sales and Pricing, etc.
I'd be at $12 with vinyl MM64 -
That or the strip of metal where the cutting strip is glued to... MM64
If there is an overcut setting in the program your using set it at .100 and that should fix the incomplete cut MM64
Anyone have a silhouette of a Drag Racing Motorcycle?
MrMopar64 replied to Xw00dsrac3rX's topic in Graphic Requests
here's one MM64 Drag Motorcycle.ai -
Why do you need to turn text into paths? I just type in what I want and tell SB to cut it never had a problem. MM64
Under the cutter set up menu Also under File... workspace set up Now I'm new at SB but I think that will do what you want
Did you change the media size in SB? MM64
Just when I thought Ebay couldn't get any worse
MrMopar64 replied to BannerJohn's topic in General discussion
What they said....^ The sellers that sell things for .99 cents and $14 shipping are the ones to blame MM64 -
I'm using a graphtec 5000-60 and ai my problem is that when I use cut master 2 the cutter will see the frist reg mark but when it starts to move to the 2nd mark it only moves about 4" and stops the 2nd mark is 13" from the first Now if I open Graphtec plotter controler it will see all 4 reg marks... So I'm thinking I'm missing something in AI Please help Thanks for any help MM64
Thanks for your time and info but I don't seem to have the tabs you are talking about I show a rip/print button but no print/cut And I don't find reg mark on any of the tabs I'm using Flexi pro 8.1 so I'm still lost Thanks again MM64
File is cutting twice and yes I did use the serach button...
MrMopar64 replied to MaDeucePaint's topic in Adobe Illustrator
I can't say for sure but I think it could... just remove it and give it a try MM64 -
Yeah the way I understood it was that if you set it to 0 it would still go around twice but cut the same line MM64 -
The only thing I can find in Sign Blazer that MIGHT cause this would be the Duplicate Position under Perferances MM64 -
Not sure what cutter or program your using but in the cut window there is a setting for how many passes you want the cutter to make I think it's under the advanced tab MM64 -
Another try That looks better megaphone2.ai
Here is another... MM64 OOPs Well it didn't attach the file
So at that point you are printing the image from Flexi then cutting from Flexi? Can you give me alittle info how to do it from Felxi Thanks MM64
I'm using 11x17 jpss and the program I'm using Illy with cut master 2 The image I made was done in Illy so thats the reason I'm using it Is there a way to take an image from Illy and cut it in flexi and use the Illy reg marks? Thanks MM64
Yes they are between the rollers
Workforce 1100 & AI
CE5000-60 load media prompt
MrMopar64 replied to mikeguam's topic in GraphTec Cutting Plotter Discussion
If it dosen't work with the wires togther try it with them seprated... as it might be a n/c switch -
I just thought of something else.... I bought my cutter broken and have had it all apart and there is a micro switch on the handle that you raise the rollers with it is under the right hand cover...as soon as you move the handle to release the rollers it puts the cutter in the load media mode if the switch is bad it will not know if the handel is up or down to test remove the cover and jump the 2 wires on the switch togther if that fixes it then the switch is bad you can run the cutter without the switch as long as the 2 wires are hooked togther That switch just tells the cutter if the handel is up or down Let me know what you find MM64 BTW... if need be I'll pull the cover and post pix just let me know -
The media sencers are in the base... they are the 2 (1 front 1 back) ovel shaped holes below the long blue strip Try covering them with tape just to see if that makes a differance... you can't run with them covered I think you can go in the programing and turn them off MM64 -
Thanks!!! MM64
Thanks! Can you tell me why when I open the file in AI it dosen't look like the jpg What do I need to do Thanks again
