Everything posted by pastortommy
Try putting your image in the cutter in the opposite orientation.
I use a program called "MIS Autoprint" to schedule my sublimation printers to auto-print a file (purge4) every 3 days to keep the heads in good shape when I am away. This is on an XP computer. The new computer, running windows 7 (64 bit) will not run this program and there is no update for the program. Do any of you know of any auto-print program that will do this operation?
I will try this in the morning. Thanks.
Does anyone have a graphic of the terrier in the Boston University logo that that they would share?
I use Vectormagic, desktop version. Works well with minimal input.
Laserpoint contour cut software
pastortommy replied to TomasB's topic in LaserPoint Cutting Plotter Discussion
Instructions for setting up a LaserPoint cutter to enable contour cutting with FlexiStarter 8.6 or 10. (These instructions are written under the assumption that you have already set-up your LaserPoint in Flexi Production Manager and have it operating properly for regular vinyl cutting). The first thing you need to do is create another setup in Production Manager as follows: Open “Production Manager” – choose the “Setup” menu – choose “Add setup”. (The following screen will appear): Click on the down arrow under “brand name” and choose “Creation-PCut”. DO NOT choose “US Cutter”. Next, click on the down arrow under “model name” and choose “CT-630G”. Your “Add Setup” screen will now look like this: Click “Next” and this screen will appear: *1 – choose the same “COM port that is assigned to your LaserPoint” setup. *2 – choose “None” for the Flow Control. Click on the “Finish” button. There you go, Your LaserPoint should be ready to do some contour cutting. Just choose the correct cutter in the “Cut Contour” window in FlexiStarter. Good luck and again, Thank You Skeeter. -
Skeeter, thanks for being persistant on this one. I got it to work with advise you gave. I also figured out a way to also use the laserpoint to do the alignments. I will post a walkthru of the proceedures in a while. -
Again, Flexi 8.6 and 10 will not allow contour cutting with the LP cutter. It will not bring up the alignment window with an LP cutter. I have even tried it with the pcut driver installed. During the same testing SB cut the contour perfectly. The MH series cutter will contour cut with the mentioned software with no problems. -
You cannot do contour cutting on a Laserpoint with flexi starter 8.6 or 10 -
Laserpoint cutters do have a serial port
Will this do? baby-rattle.eps
Will this work for you? hotcake.bmp hotcake2.eps hotcake2.ai
I agree with SA Graphix. You can't go wrong with Richard and Cobra Ink Systems.
I agree, best support a person could ever hope for!
Another attempt at conversion to IP.Board
pastortommy replied to marcuso's topic in Community Rules & Announcements
Like it so far. -
+1 on to much heat
Thank you. I grabbed it as well. Going to use it to make my wife a t-shirt for her "retirement" birthday.
Thanks, I grabbed them all!
Thanks for the help!
Do you have everything inside of the "workspace"?
Spray a fine layer of "static guard" on the back side of the heat press vinyl before you start cutting.
Ditto, happy thanksgiving all!
To answer the original question. I would cut it in 3 sections just for the ease in handleing during the install.
When I had a problem importing in SB I uninstalled and reinstalled the software. I haven't had any problems with it since then. And I have preview turned on. Try reinstalling. But be sure to uninstall first.
Grabbed both, thanks.
