Days Won
21
Everything posted by mb20music
set the pressure to 80 and adjust the blade so that the blade sticks out a little more.
Can't you just cut vertically instead of horizontally on bigger jobs?
this is it right here click here
Brody Script is close - it comes with SignBlazer
you do your text then weld it then you can adjust spacing to how you want it.
very professional looking, nice job
Signblazer Elements Trial doesn't need a registration code as it never expires. Try this link here SB Elements
Oracal 631 is easily removeable and is very inexpensive. I think around $20 for a 24" x 10 yd roll.
Iron on material that does not require a heat press
mb20music replied to FasTech Design's topic in T-Shirts and/ or Garments
EnduraTex makes iron on vinyl, never used it but it is the only iron on vinyl I am aware of. I believe Signwarehouse carries it. -
x2
If your budget allows, get the Graphtec - you will not be disappointed. Plus it can cut letters down to 1/8" and the smallest the Copam will do is about 1/4" (depending on font).
I've always used my older blades for magnets, but go ahead and get some new blades they are pretty inexpensive and last a long time.
it will not stick to the machine, I have cut quite a bit of magnetic material just fine. You don't want to cut all the way thru, just enough so that you can bend the material and it will break off.
just have to bump up the pressure and adjust your blade so that it sticks out far enough to cut about half-way thru the magnetic material.
Problems with Tape and Vinyl
mb20music replied to psychoCutter's topic in Criticism and Complaints about USCutter
you need a high tack transfer tape for 631 -
for large quantities get them here at uscutter for smaller quantities purchase at Signwarehouse.com signwarehouse
http://www.dafont.com/mostwasted.font
what transfer vinyl are you using and what kind of fabric is the shirt?
Copam 4050 help needed
mb20music replied to born2boost's topic in Copam Cutting Plotter Support Requests
copam board
