Afternoon all.
I see some great advice given on this forum and I am pleased to see a forum for Mac users! Since Mac is the standard for graphic creation and manipulation you'd think there would be more people using a mac based system. But maybe its a good thing that not to many have caught on yet
So I have a small ( at least I hope its small ) issue with a system I am trying o hook up at home. I purchased a Jaguar JII-76s Vinyl Cutter for my son and daughter as a small business model. They are only 14 - 16 but its never to young to start right ? Well the plotter I know works as it was a system we had at my Company and it was hooked up to an old imac with OSX 10.3. I have a dual CPU G5 Power Mac with OSX 10.5 at home so I didn't buy the Imac unit.
The Cutter came with Flexi 7.5 Mac edition, a dongle and a serial to USB cable for connecting the Cutter to the MAC.
I installed the software with no issues at all and the dongle allows me to use the software and send files through "Production Manager" to be cut. Production Manager try's to send the file to the cutter but reports that it " could not open the port " I thought that the Serial/USB cable may have been the issue so I brought a new 2.0 USB cable and connected it to the Cutter directly through USB. Still no port.
Production Manager gives you the option to locate and set up your cutter, but when I plug the Cutter into the USB port it only shows as a "USB-Printer" I went to the Mac System controller to see if I could "install" the "printer" but the System does not recognize it being connected at all.
Drivers where the first thing that came to mind as the cutter did not come with any install disks, but I went on to read the Flexi has built in drivers for my model of cutter, sure enough it does give me the option in Production Manager for my Cutter. I use this for the set up.
I have read on this forum information about port drivers for the Mac ? I am wondering if this may be the cause of my problems.
I know the cutter works and I did a test cut available as an option on the physical cutter and that worked fine. I know the software is good as it does everything BUT cut. so am I right in thinking the this is either a Cable or a Port driver issue ? The reason I am asking is ti see if there are any known issues with this set up that i maybe over looking... plus its always advantageous to have someone " check your math "
I appreciate any feedback team, my kids thank you also !
