30-284
Members-
Everything posted by 30-284
I think that is a basket only no stand. Donn
Even easier in scalp, Object>MERGE, and that's it.
Check out the for sale section, there is a 24" copam listed which is one of the best stepper motor cutters and works fine with many programs. Donn
- 35 replies
- 1
- first cutter
- buying
(and 5 more)
Tagged with:
Using the file from devil, I just put registration marks on it. Just ungroup it, separate them and cut out of the different colors, Then use the registration marks to line the layers up. is this what you are asking about? Donn PD.svg
In your fill and stroke box on the right side of your picture, highlight the part you want the color changed on and chose the color. Donn
serial number is listed under help>about sure cuts a lot.
- 1 reply
- 2
No, I am using a copam but like others have said in other posts, I have another blade holder with a 60 degree blade all set up. All I do is change the holder and set pressure to 300 and all is good. I keep the speed the same but I dont have it set all that fast to begin with. Donn
300 grams of pressure should do it in 1 pass, that's all I ever use and never fail to weed all holes at once. that is with a 60 degree blade as well. Donn
Newbie in Cleveland - Need help with rhinestone templates
30-284 replied to iam1ofhis's topic in Introductions
When you have your cutter adjusted right then you should be able to pull the sticky flock up and have all of the little round dots stay. I use almost 300 grams of pressure on my copam to make sure i have no troubles, it works great every time. -
If the stones did not adhere and are still applied to the transfer then your good. If everything is still in place and nothing has moved then wait till your press shows up and reapply.
- 13 replies
- 1
Some irons won't get nearly hot enough, also remember to place a Teflon sheet or parchment paper inside the shirt or the glue from the rhinestones will glue the front and back of the shirt together. Temp should be in the neighborhood of 300 degrees.
- 13 replies
- 1
Re do the text, and replace the hat and scroll. that distressed font would be a pain to weed.
Western is close but with out all of the distress, that would be a pain to weed. locate the scroll and hat, don't trace the text if you don't have to.
Both brothers are. I don't think he needs a sign to tell people that.
Shredded letters... =/
30-284 replied to PhaedrusZen's topic in TITAN 2 Series Vinyl Cutter Discussions
I hope you don't mind me asking but, what was the reason that you changed from the Titan to a Graphtec? Donn -
Your welcome, if you have a chance, let me know the size of the light bar or the completed sticker when your done as the actual size I have not been able to confirm.
- 27 replies
- ps4
- controller
(and 1 more)
Tagged with:
Is this the one? if so you will need to size it first, once you get the size correct then repost it as that's all I need is the correct size, I don" have the controller. ps4.eps
- 27 replies
- 2
- ps4
- controller
(and 1 more)
Tagged with:
If I remember correctly, you can only union 2 items, so try and group the 2 red lines as one and then make sure that the stiches are grouped as well then use union and see what happens. At least I think that's how it is in SCALP 3. Donn
All of these responses within 15 min of the post and nothing from the op.
30-284 Caliber of pistol I hunt with.
For rounding the corners, take a look at the We R Memory Keepers Crop-A-Dile Corner Chomper Tool, they work great on the magnets and have 2 radii 1/4" and 1/2". Donn
I have cut it with my copam and I know that works perfect. Just need to adjust the blade to extend out further than normal, I have a separate holder just for sticky flock. Donn
Probably wont find too many will help being it is a copyrighted image with the copyright held by Seamartini Graphics, but if you want to purchase, it is available from Shutterstock.
You can always take your heart and then go to object and put a shadow behind it (you can play with different sizes) then draw a new box around it and use the back minus front under path and you will have your outline, then color it to your choice. This is all in SCALP 3, hopefully 4 is similar. Donn
