Everything posted by sdgirl
I know it is an old post but I wanted to say thank you for the image!
I have a customer who wants to have a decal made for his trailer. It is in brushed chrome and well be 8" x 10.66 feet long. He will be putting it on so my cost is just the cutting of the decal. Any help with price would be great. I usually do so much a square inch but it has been awhile since I have done something so big and in the brushed chrome. Thanks! Christi
I am not sure what the name was on here or if the post is still here. Maybe if you search for it or if someone else has the link to it?
Thanks Scooby. I do have a program from here that helps calculate the cost per inch.
Thanks for the advice. I had an idea of what to charge so I will go with that.
Thanks. I will figure it out. I have a few other sign people within a 50 mile radius and just don't want to charge to low or to high. I know some people on here charge $3 a sq ft. Some charge more. Some do it by the inch. I haven't been doing all that much in the past few years for decals so I feel a bit out of the loop. I don't want to charge 5 cents a sq inch when others are charging 15 etc. Thanks, Christi
I have it on hand
Thanks Dakotagrafx I have the gold as well
Does anyone know where to get a bronze color in chrome? Thanks, Christi
Thanks. That might be as close as I well get.
Hi Everyone. I have been reading thru all the posts to see if any match mine and haven't found anything yet. First off awhile back I went to click on my SB icon on my desktop and a window popped up saying that the "SB.exe that is this shortcut refers to has been changed r moved and it won't work properly. The only way I can now open SBE is going to the program files and clicking on sbfiles and picking the file I want. No biggy there I figure out that much. Now here is my next issues. I have 2 cutters. Vinylepress r series and the mh721 that I use. Lately it seems that when I send my file to cut that it starts off and then freezes and doesn't finish. It seems like I have to reboot my sb and my cutter to hopefully correct this. My big issue right now is that I send my file to cut and it just stays in that window and not sending it to my cutter. It doesn't matter which cutter it is either. I have tried different usb ports etc. I actually have another laptop that I just downloaded the SBE program that I got from UScutter when I purchased my machine. It also gives me the same message about the desktop icon? I tried to download the update off of here but none are working. Now I go into the program go to cut and it is still just thinking? I actually got it to cut one time and it froze in mid cut. I am assuming that is because I have the original version? I have an order to fill and this is getting a bit frustrating so any help would be appreciated. I have been cutting off the other laptop and SBE program for years with these same cutters. I am not sure what is happening when nothing has changed? Thanks, Christi
I bought the keyspan adapter off ebay, and finally got it. I am not sure how it is suppose to plug into the cutter? There is plastic that is above the plug in part and on the cutter so I can't plug it in?
I just sprayed some static guard In the air and wiped down the cutter and vinyl with a bounce sheet and still not working. If I do a test cut on either cutter it works for that, but when I plug either one into my laptop and try to cut it just sits in the sending output to cutter window or if I am lucky starts to cut but than freezes. I am just so frustrated. They were working just fine the other day. I will order the keyspan adapter and pray that is my problem. Although I have switched out different cords and each cutter has a different one.
Great thank you. I will do the dryer sheets and spray static guard in the air. Yes I do have the them grounded to the stands. I am going read up on the link. Thanks
okay thanks. I just tried the refine mh721 again on my older laptop with the sbe that I have been using for years. It started to cut and now froze. Would that be the connection or is there something else I can try?
It only does that when I send it to cut and nothing happens so I unplug the cable. Does both of these units work on vista and windows 7? I used the cutters yesterday and my mh721 worked for one decal than after that this issue started. The vinylexpress r series started cutting and stopped in mid cutting and wouldn't start back up again and today neither well cut or work. I am hoping that if I do order one of these units that well solve my problem?
Thank you. Do you think this is my problem? When I use the usb option and it is just freezing up in the sending to my cutter stage if I unplug the cord I get the warning that can not open the output device error. Otherwise it would just sit there all day long. This is happening on both my laptops so I know it isn't the computers and if it is happening to both the cutters I am confused.
Thanks I uninstalled and reinstalled sbe from to link you sent. On the laptop I did today. I don't have one of the cables you suggest. Where would I be able to find one? Now that I am in the sb that I just downloaded when I goto cutter it isn't showing any of the refines? Actually the list has a lot more cutters than the other sbe I am use too.
Hello, I am looking for the font where it has the I Love You and the Best Thing. I have been searching and haven't been able to find it. Thanks! Christi
Thank You so much! I finally found the feel script and downloaded it. It is an open font though and I need to figure out how to open it in SB. Thank! Christi
No I didn't go to dafont.com. Thanks for the search I will go thru them! Thanks, Christi
Looking For A Cherry Blossom Branch/Tree
sdgirl replied to Kelleybell123's topic in Graphic Requests
Your welcome! I am glad I was finally able to post something! -
I think this is one? cherryblooms.eps -
If your looking for a shirt supplier in the midwest..
sdgirl replied to Friedrich07's topic in T-Shirts and/ or Garments
I use S&S activewear and I get the shirts in 2 days max. The bad thing is the shipping and credit card fee. I haven't heard of Bodek and Rhodes? Can you view the site without being registered? Thanks Christi
