Stoke
Members-
Everything posted by Stoke
I've been lurking around here for a few weeks now and you guys are a great resource. I have learned much from reading the posts on this site and am amazed at the level of friendliness here. You don't find that a lot of places on the internet. You guys are great. I am in need of some spider webs. I did do a search here and the few that turned up wasn't what I was looking for. And the .ai files I couldn't open. So if anyone has anything else, it would be much appreciated. Thanks in advance.....
Gracias
I've done several 2 color things in the past with little or no problems. Right now I'm attempting some 3 and 4 color designs and am having a lot of trouble with the layering. By the time I get to the 3rd layer, the tape (along with everything else) is basically one big wrinkle and is pretty much garbage. Any hints, tips tricks to make things work a little better? Or am I just doing something totally wrong?
Yeah, I've searched all those out and watched them repeatedly..... I'm just not doing something right somewhere.... Its as if I need 8 hands to hold everything, etc.
I have a quantity of 4 of these to make. The size of the magnet blank is the standard 12"X24". What kind of prices would you guys come up with? Thanks for the help!!
Magnetic sign pricing help
Stoke replied to Stoke's topic in Business Practices, Sales and Pricing, etc.
Thanks for the help guys. Now one more thing..... This was going to be a 3 color design on a white magnetic blank. Lets say we remove the magnetic blank and add a 4th vinyl layer thats a white oval. Now the finished size would be 20" w X 13" h. How much would that change your estimates? -
Heres the first banner that we attempted. Thanks for the help on the questions that I asked beforehand!
This one was 3'X5' and I did it with a 24". Just have to learn where to piece it....
Thanks folks. It was a major learning experience.
ok...possibly stupid question here. I'm getting ready to attempt my first banner and in the process, the largest thing I have attempted size-wise. I'm a little unsure of something that may be obvious but I don't want to waste a whole lot of vinyl if I can help it.... anyway.... The banner is 36" X 60" and will have 2 colors. Its basically an outline of North and South Carolina (in black) with an image of a car inside (also in black) and three lines of red text. Two of these lines of text interact with the states outline - above and below the car. The third line is below the outline and shouldn't present a problem. Anyway, my main question is, can the layering be done on the banner itself or am I gonna have to do it on the application tape like I would a much smaller image? If i put the 1st layer down wet, once its completely dry, can i do the second layer without the tape pulling on the 1st layer? I done plenty of small multicolored window stickers but nothing anywhere near this large. Again, it may be obvious once I do it but I'd like to have a bit of an idea of what may happen before I start. Thanks in advance for the expert help you guys always willing to share.
Oh sorry....brain cramp there. I meant to say "I didnt spray as much as the first time"...... just forgot to finish the sentence for some reason..... I lightly sprayed the area on the banner and very very lightly sprayed the vinyl....
Sometime back I had read a thread about the various recipes for application fluid. What I mixed up apparently was way short on the alcohol and was basically water with a squirt of soap. When I wet everything down and placed the letters, there was too much water and it would never dry. 2 hours later it was still wet and and the letters just peeled right back up - nothing would stick. I peeled everything back off, dried the banner material completely and then cleaned it off with denatured alcohol. This time I mixed up a new batch of fluid using 3 cups water, 1/2 cup alcohol and the small squirt of soap. For the second attempt, I didnt spray. We placed the letters, got them positioned, squeegy-ed eveything out, and within minutes peeled the tape off. This time everything stuck just like it was supposed to.
2nd attempt went much better. Pic will be posted in show your work.
I must have started "too wet".... after cleaning the banner and getting everything read, i put the first part down. I got it placed where I wanted it and started squeegy-ing.... I thought I had it pretty dry and even left it sitting a couple hours. I came back and everything jsut peeled right up....nothing stuck. Oh well, I'll re-clean and try again with less liquid this time...
PCUT Shipped today
Stoke replied to TexasFocus18's topic in Creation PCUT Cutting Plotter Discussion
www.esnipe.com -
Looks good.
Well, with signblazer, the option to change the offset is in the cutter setup.
I'm one of those people. I come here several times a day and read all new posts. I am too new to the whole cutting process to really be of any help so I defer to the exerts and let them answer the questions. Plus like FM says, anything you need to know has pretty much already been answered so spending 5 minutes searching will generally get you what you want to know.
irfanview does NOT do what I need it to do. I've tried it twice now and gotten the various plugins. It (along with other software) will not preview all of my EPS files and I cant get it to preview an .AI file.
Does anyone know why some EPS files are previewable in viewing software and others are not? *edited because I found my original question in a different thread*
**originally posted in the wrong section** ;D I had the end cover off the PCUT yesterday and I noticed the motor seemed to be just "hanging" there. There were 3 black rubber cushins of some sort and the motor was only attached to 1 of them. It looked like it was intended for the motor to be attached to all 3 but it was obvious that they had never been attached. Basically one screw in one of the rubber cushions and the drive belt going from the motor to the roller was the only thing holding the motor in place. I'm gonna go out on a limb here and guess that something ain't right here. Anyone know what I'm talking about? And no, unfortunately, I didnt take a photo of it while I had the cover off.... Thanks!
From the looks of it, 2 of them were never connected to begin with. I will need to take it back apart and see of I can figure out whats going on.
And I realized I put this in the wrong section...
