Everything posted by mikerob2334
just for fun
you could use this one and just stretch it http://www.dafont.com/athletic-supporter.font?text=HC
jay, you love that polyline don't you i use it too but if inkscape will do it faster i go that route. call me lazy
Did it in Inkscape, open pic-path-trace bitmap. save as eps & import to sbe
Don't think there is. That file is just a list of fonts and names. Here it is if you want it: http://www.4shared.com/file/143387329/14a3c59d/FontManl.html
vinyl not wanting to stick to banner
mikerob2334 replied to scottboy1973's topic in General discussion
like me & bannerjohn said, are you rolling the banner vinyl in?? that would cause this -
you can try here http://www.logotypes101.com/default.asp right here... You can search for it, brandsoftheworld jr thanks for the link. 1st time i've seen that one
Learn something new every day -
I was wondering if I read that right wonder what all is in it?? -
leave the washer fluid out. what kind of alcohol are you using (use isopropyl) and roll your banner vinyl out. you could also do it dry. unless it's something that really makes me nervous about a possible bubble i do mine dry. -
here's one carolina panthers.EPS carolina panthers.EPS
here ya go pumpkin.SBD pumpkin.SBD
welcome. glad i could help
here's one without the # blanket harness race(2).EPS harness race(2).EPS
You mean where the # goes? what color, same as the horse?
posted one here http://forum.uscutter.com/index.php/topic,23021.0.html
will this work? harness race.eps harness race.eps
$8 a bag sounds good. What grit is that stuff?
What media did you use? I'm going to Harbor Freight today to pick up everything so I can try this.
May seem like a no brainer but make sure you get rid of as much excess app tape before you apply. A few extra inches of tape makes it a LOT harder to get all the fluid squeegeed out. And nukleon, you can use the clear in a pinch, you just need some time and a good arm. I thought the same thing until I ran out of paper app tape and tried it with clear.
Received my 3rd cutter and still problems
mikerob2334 replied to MaderDesign's topic in General discussion
It's obvious the sbd rockstar file mader posted is a problem (not saying the only problem). I cut it from sb and got the same very pronounced jagged lines he's getting. Deleted some of the "curve" nodes on the straight lines and cut it again, it straightened out. -
I've had this problem with certain types of ai files when they are in the same folder. Try moving the ai files into a seperate folder or if they are copies of the eps you can just delete them.
Ok Mader, I may have it here or I may be crazy. I've never had this problem or so I thought. I cut some test cuts and a square on a skew. Looked at it with magnifying glass and it is wavy just can't see it with the naked eye. I tried playing around to make it worse and I did it. Don't have a clue what the espeed is for, searched here and found nothing. But mine is set to +5 and never a problem. When I changed this espeed setting the waves became visible with naked eye. Again not a clue what it does but try changing yours and do some cuts. Couldn't hurt. -
No problem kenya. after you said that i looked closer and realized the paths crisscross all over each other. stuff like that drives me crazy, glad you got it worked out
