Everything posted by mikerob2334
:thumbsup: :thumbsup: :thumbsup:
tossed these together deer sihouettesz.EPS deer sihouettesz.EPS
No loophole, just lucky people. A lot of it has to do with volume. More volume the more chance of getting nailed.
Is this what you wanted? Found a stray node in lower left ChiefsTags.SBD ChiefsTags.SBD
From copyright.gov: Uploading or downloading works protected by copyright without the authority of the copyright owner is an infringement of the copyright owner's exclusive rights of reproduction and/or distribution. Anyone found to have infringed a copyrighted work may be liable for statutory damages up to $30,000 for each work infringed and, if willful infringement is proven by the copyright owner, that amount may be increased up to $150,000 for each work infringed. In addition, an infringer of a work may also be liable for the attorney's fees incurred by the copyright owner to enforce his or her rights. Whether or not a particular work is being made available under the authority of the copyright owner is a question of fact. But since any original work of authorship fixed in a tangible medium (including a computer file) is protected by federal copyright law upon creation, in the absence of clear information to the contrary, most works may be assumed to be protected by federal copyright law.
i own an hvac company. pretty sure the problem is a short in the temp switch. (you said it blows the outlet when you turn the unit to "cooler", right?) i would def get the landlord to have an electrician check your apt wiring but if the wiring in the apt checks out he might as well replace the window unit as anything you do to these will cost as much or more as a new one.
talk about waaaaaay off topic it sounds like the temp switch has a short in it at a certain point.
no problem. i have a few more but too large to upload. if you search from alltheweb.com you should be able to find them
one of them. always playing
2005 convertible vw 2K5BugConv.eps 2K5BugConv.eps
Here's another one you can play around with. angles are off on this one too salon k pink.SBD salon k pink.SBD
Looks great what were you having trouble with on th lp graphic? vectorizing it?
no problem. i've never seen a font with one but i'm sure someone has a font drawn up somewhere
here's the sbd file for you You can make this is your signblazer. text two I's in new roman bold. then break the nodes using node edit and join them. good practice roman numeral 2.SBD roman numeral 2.SBD
This work? roman numeral 2.EPS roman numeral 2.EPS
punched has holes in side for tractor fed plotters. unpunched has no holes. in your cutter is not tractor fed then you want unpunched
Thanks
Try this one http://rapidshare.com/files/174179239/003_camouflage_print.rar
Does anyone have a vector of the Gadsden flag??? (don't tread on me) I've tried to vectorize one but can't get a image good enough. Thanks
My first thought was that some MH cutters ship with tape over the cutter strip and will cause vibration/noise if not removed. But you said you ran it w/o the blade? Took out blade and holder???
looking for a skeleton riding an motorcycle
mikerob2334 replied to tiggs's topic in Graphic Requests
Thanks -
i'm looking for the "rasp" font. does anyone have this or a link to download?? thanks
That was it, THANKS!
Does anyone have this font or know what it is?
