rrc62 0 Posted June 8, 2007 How do you all handle this? Currently, I apply the top layer to the bottom layer on the bench using clear tape so I can see the registration marks, then apply the whole thing in one shot. I think the most sensibe way would be to apply the first layer to the sign blank, then the next and the next with a light spray of app fluid between layers and aligning the registration marks at each layer. Sound about right? Thanks...Ross Share this post Link to post Share on other sites
Guest Terry Posted June 8, 2007 I do it both ways, depends on how large it is. Terry Share this post Link to post Share on other sites
rrc62 0 Posted June 8, 2007 If you apply wet on the sign, how do you line up the registration marks through the paper app tape? Same would apply if you were to apply the top to the bottom on the bench wet. You would still need to use paper app tape. Ross Share this post Link to post Share on other sites
TaterNuts 3 Posted June 12, 2007 well... Wet paper application tape is more transparent then dry... Share this post Link to post Share on other sites
