vetsen 0 Posted May 3, 2007 My plotter seems to cut everything about 2.5 times larger than what I have the image set at. I also have the problem where the cutter slices the first character. Is there a scaling setting in signcut? My setup Mac mini PPC G4 1.25 ghz OSX 10.4.8 Refine 25" plotter Generic usb to serial converter (looks just like the I/O gear model) I/O gear driver for usb to serial converter Signcut 2.16 Share this post Link to post Share on other sites
kenimes 42 Posted May 3, 2007 You set the size under the images button in SignCut. Also make sure you have the settings set to inches. You may also want to download the latest version of SignCut for Mac from www.sc-x2.com, just go to customer login, then downloads. Share this post Link to post Share on other sites
hairyconiption 0 Posted June 6, 2007 In sign cut go to the settings>settings>units and change it to inches or cm or what ever unti you are measuring with. Share this post Link to post Share on other sites
