gabbssss 0 Posted March 13, 2021 So i just got my titan 1 gutter and i use sure cuts a lot 4 pro but i’m having issues cutting my projects it keeps cutting lines inbetween!!! What do i do im so frustrated! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 13, 2021 This is usually caused when the Sure Cuts A lot software, has not been activated. Craftedge.com is your tech support. https://www.craftedge.com/activation/activate.html If the software is activated, then maybe you don't have your blade depth set correctly. Don't use any instructions that have to do with using a credit card or post it notes. They are wrong. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should barely see and feel the blade out of the blade holder. Regular sign vinyl is only 2-3 mil thick. You only cut with the very tip of the blade. 1 Share this post Link to post Share on other sites
