MerchForFans 0 Posted November 24, 2020 Hey everyone! I'm new to cutting and bought a CE6000-60 and it's been a nightmare getting this thing to contour cut. Cutting using Cutting Master 4 within Illustrator. I've done the test sensor sheet on regular paper and it reads flawlessly and cuts just as flawless...but when trying to do a contour cut with matte laminated vinyl, I have wasted so much material due to it never reading the marks past thee first on. It always hangs on the second and doesn't read it. Even though the sensor scans directly over it. I'm using 3/4" length and 0.99mm thickness on the marks with a 1/2" margin. I've tried with the marks laminated and with cutting the laminate around the marks. Any and all help would be so appreciated. Thanks everyone! Share this post Link to post Share on other sites
jmas 119 Posted November 25, 2020 When you load the machine, do you press 1 for "front edge" or 2 for "start from here"? Mine will not find reg marks unless I use 2. Share this post Link to post Share on other sites
