maklinedinst1962 0 Posted November 8, 2020 i cant help from thinking that i got screwed buying this sc2 cutter , i have spent hours trying to setup contour cutting and the instructions must have been written by a first grader, and my cutter isnt doing what the instruction say it should be ,there is important parts of information left out of the instructions or at least its not all complete, i am tired of this thing now ,its soon going in the trash heap,and its almost impossiible to get help,when i do a contour test cut sheet the pen lines are a inch and a half higher on the sheet, not even close to where they should be,ive about had enough now. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 8, 2020 first spamming your post all over in other peoples post will not get you help faster - the duplicates will be deleted. in none of your post I have read have you said which software you are using to try to contour cut and exactly what is it doing? I have never had a sc2 but for someone to help you it will be helpful for them to know what software you are using and what OS? Share this post Link to post Share on other sites
