timbo6470 0 Posted May 24, 2008 Can anyone let m knw if you can cut cardboard on the refine series of cutters? I not talking really thick carboard. Myabe the thickness of a standard busines card or slightly thinner. I need to do some mockups for a client and was hoping the cutter could cut me out some intricate shapes on cardboard. thanks Share this post Link to post Share on other sites
Popeye 0 Posted May 24, 2008 I have a Pcut... but I cut card stock all the time. Most business cards and the card stock I use is .010" thick. I would think the Refine could cut it too. Share this post Link to post Share on other sites
Jay2703 704 Posted May 24, 2008 I have a Pcut... but I cut card stock all the time. Most business cards and the card stock I use is .010" thick. I would think the Refine could cut it too. Popeye, what do you use for backing when you cut? Share this post Link to post Share on other sites
Popeye 0 Posted May 24, 2008 I tried using a backing to start with and it never really worked well... I don't use a backing now, I just set the blade so it just barley cuts through and I've gotten excellent results. I was using a couple strips of masking tape over the cutting strip to protect it... that worked pretty well but I wanted something better. Picked up some UHMW tape and that seems to be holding up very well. Share this post Link to post Share on other sites
Jay2703 704 Posted May 24, 2008 I tried using a backing to start with and it never really worked well... I don't use a backing now, I just set the blade so it just barley cuts through and I've gotten excellent results. I was using a couple strips of masking tape over the cutting strip to protect it... that worked pretty well but I wanted something better. Picked up some UHMW tape and that seems to be holding up very well. Thanks, I will give it a try. My wife does stamping and I though it would be cool to do cards with cutouts or different shapes. Share this post Link to post Share on other sites
Popeye 0 Posted May 24, 2008 Make sure and let us know how you made out.. Thanks Share this post Link to post Share on other sites
timbo6470 0 Posted May 25, 2008 thanks for the advice all! Im going to give it a try tomorrow and let you kno how it goes. I had another tip from someone saying that when they cut cardboard they put a bit of the backing from some old vinyl on the back of the cardboard to prevent damage to the cutting strip. They said that they use a bit of low tak spray adhesive to make it stick nicely to the cardboard. I will keep you posted tomorrow. Can anyone give any advice as to what pressure to set the knife to? I was thinking 170??? Tim Share this post Link to post Share on other sites
