ehrichweiss 1 Posted November 26, 2019 Let me start off by saying, I'm a magician and it leads me into some of the most interesting fields while trying to accomplish some of my feats. I happened to need some paper cut in a very specific place and decided that while I could use an Xacto knife, I would prefer something with a bit more precision. In my brainstorming I realized I could use a vinyl cutter and considered my Cricut but I'm really unhappy with how it works and I need this paper to not curl which it will tend to do if I have to pull it off of my Cricut's mat, so I decided to look for a used vinyl cutter and I actually found 2 that were working and in pretty good shape, a GCC Sable, and a Graphtec CE2000-60. The guy selling offered me pair for $50 more than I was about to buy the Graphtec for so how could I resist. I'm currently wrestling with getting the drivers/hardware setup just right for the Graphtec(the previous owner was using a USB<->parallel adapter that I can't seem to get seen as a printer even though the system knows its there) but I got the Sable up and running in a few hours after wrestling with the driver installer that kept telling me it was the wrong size(I have a solution for that if anyone ever needs it). Anyway, one of my projects requires me to score the paper for creasing. I know that scoring "blades" exist but I'm unsure where to look for them, especially for my Sable. Anyone got any leads? Also, should I be using a paper-specific blade for cutting or will the vinyl blade suffice? Thanks for reading my long intro and thanks in advance for any help offered. Eric 1 Share this post Link to post Share on other sites
bikemike 711 Posted November 26, 2019 If you try to cut paper on any cutter without a cutting mat you will destroy the cutting strip. So that part is out. For a scoring blade, I have no idea. ebay maybe? 2 Share this post Link to post Share on other sites
ehrichweiss 1 Posted November 26, 2019 Just now, bikemike said: If you try to cut paper on any cutter without a cutting mat you will destroy the cutting strip. So that part is out. For a scoring blade, I have no idea. ebay maybe? That's good to know. Are there any good cutting mats that don't require adhesive, or maybe have a better adhesive than the Cricuts use? Share this post Link to post Share on other sites
bikemike 711 Posted November 26, 2019 From what I have seen, there is different tack cutting mats out there. No idea what would work with paper. Unless someone else has done it, you would have to go with a trial and error. 2 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 27, 2019 I have used clear application tape as a backing for some small projects at home where I needed to cut paper, even paper app tape should work maybe do two layers. I have a cricuit cutting mat too and I know hat you mean about them being so sticky they cause problems. Scoring blade - no idea other than sanding a tip off a cheap blade maybe? 1 Share this post Link to post Share on other sites
