fmccauley
All of a sudden can't connect to cutter
I have a Titan 3 cutter and use Sure Cuts A Lot 3 Pro.
I have been using this set up for over a year with no problems, but the other day when I went to cut, the program couldn't connect to to the cutter.
I've tried all the standard trouble shooting suggestions, I've reinstalled the driver, tried new usb cords, even tried a serial cable.
Any ideas?
No mention of which computer operating system.  Computer updates can cause this.  Try rolling your computer back to the last time it worked correctly.   Try a different software trial. It won't cost you a penny.    Then you can rule out drivers, software etc.
I'm working on a mac, I haven't updated anything so the system should be the same.
But I did install a trial on a different MacBook Pro, installed the driver and everything and got the same result when going to cut, the program can't find the cutter.
Which software trial?
I would get away from SCALP.  many problems with it.   Has Scalp updated?  Have you tried SigncutPro?  It works with a Mac.
I only use Windows, so I don't know anything about a Mac.
I had tried a SCALP trial on the MacBook.
So I just downloaded SigncutPro 2, installed it, set it up for the UScutter Titan 2, and then tried to do a test cut.
A progress bar flashed quickly but nothing happened with the cutter...
Contact UScutter tech support.  They are open now.  Pacific time.  Give them a call.
You said you set it up for a Titan 2?  You state you have Titan 3( in your first post). .  Or try with one of the SAGA vinyl cutters that match the Titan 3 you state you have.    A Titan is a rebranded Saga vinyl cutter sold by UScutter.
I've tried contacting them, sat listening to elevator music for 30 minutes and was never connected with anyone.
The Titan 2 and 3 are exactly the same so its not an option to set it up as a Titan 3, but I'll try the the SAGA.
Is it possible that USB/serial module just all of a sudden went bad?
Haha, well I am pretty much a noob! :D
For some reason I can't view that page, it says there's some Unsupported plugin.
I tried the SAGA setting and the same thing happened, real quick progress bar flash but nothing with the cutter
