UTLTRN 0 Posted August 8, 2018 We have a Titan2 cutter at our print and design shop. We are trying to cut a 72" x ~23" piece of vinyl. Though large it is just two lines of text, very simple. We've done pieces this large and even more complex without problem. This time, however, the cutter will get through anywhere between 12" to 24" of the vinyl, pause briefly, and then start over, recutting the same letters it has already cut. Until we go into the print queue and delete the job (which displays "Error-Printing" in the details of the job), it will just continue to recut and recut. Even if we let it run (I have taken the cutter offline and removed the blade to let it run and see if it would ever try to cut the whole job), it will never advance past the point where it stopped the first time. It just keeps repeating. We were worried the file was damaged, so made a completely new version of the file from scratch and it did the exact same thing. The file was made in Illustrator both times, with the text typed in to two text boxes and then both texts outlined. We saved the files as .eps as we always do for the cutter. Instead of continuing to waste vinyl making new versions of the file, does anyone have any ideas on a fix? Or somewhere to start? We would really prefer to not have to cut this in multiple pieces as the top line of text is just one long word and getting the spacing right seems like a pain we'd rather not tangle with. Because we were worried it was the fonts causing this, even though they were outlined, we made a tiny version (about 2"x8") of the same file and the cutter made it through that without issue. We've also done some other fairly large jobs since this issue first started with the problem job. Appreciate any consideration on this. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 8, 2018 Are you stating that the job stops at the very same place every time you try to cut it? And this is the only large file that it is doing it on? No mention which cutting software. On which computer operating system or how old the cutter is. Try a different trial cutting software and see what it does. You could try FREE Signblazer software and I believe they are using the Copam driver for that. Share this post Link to post Share on other sites
UTLTRN 0 Posted August 8, 2018 1 minute ago, MZ SKEETER said: Are you stating that the job stops at the very same place every time you try to cut it? And this is the only large file that it is doing it on? No mention which cutting software. On which computer operating system or how old the cutter is. Try a different trial cutting software and see what it does. Thanks for your reply! This is the only large file it is doing this on. We tried to cut the original file twice and both times we did that it stopped in the exact same place, after 18" up the roll. Then it would do the recut cycle, each time stopping at the same place and starting to cut from the beginning again. Then we made a new file and actually flipped the text the other way, starting from the end of the text instead of the beginning. That time the cutter got almost 20" in and did the same thing. We are using the VinylMaster Cut V4.0 for the cutting software, running on an older Dell machine with Windows 7 Professional. Is there another software you recommend? I'm not sure how old the cutter is, at least 2 years. Is there a way to know? The only identifying info on it is Titan^2 and a bar code. The cutter set up was all done by an employee who is no longer here so until now we've pretty much been muddling though his set up hoping nothing would go wrong. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 8, 2018 Can you post the file? Share this post Link to post Share on other sites
UTLTRN 0 Posted August 8, 2018 8 minutes ago, MZ SKEETER said: Can you post the file? I've attached eps of both the original file and the newer file, and a pdf of the newer one. In the older file, we flipped the text in illustrator as it is meant to go on the inside of the window. In the newer file we used the "mirror" function in the cutting software for this. 180802-UTLTRN-Decal-MainWindow-NEW.eps 180719-UTLTRN-Decal-MainWindow.eps 180802-UTLTRN-Decal-MainWindow-NEW.pdf Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 8, 2018 I will try cutting them on my Graphtec 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 8, 2018 How are you making that file? When I import the .eps file it shows gold around the black text. When I import the pdf my software Flexi 10 and Flexi 8.6, says the file had gradients in it. You cannot cut gradients. Why aren't you just making the file in Vinyl Master? Or even FREE inkscape. It is just text. Type it out in Vinyl Master and cut it. My Graphtec cut it just fine in Flexi software. 1 Share this post Link to post Share on other sites
UTLTRN 0 Posted August 8, 2018 45 minutes ago, MZ SKEETER said: How are you making that file? When I import the .eps file it shows gold around the black text. When I import the pdf my software Flexi 10 and Flexi 8.6, says the file had gradients in it. You cannot cut gradients. Why aren't you just making the file in Vinyl Master? Or even FREE inkscape. It is just text. Type it out in Vinyl Master and cut it. My Graphtec cut it just fine in Flexi software. Huh. I don't know why there would be any kind of gradient. We made the file in Adobe Illustrator, which is just what we normally do for most files. I will try installing the fonts on the computer we use for the cutter and typing into Vinyl Master. Don't know why I didn't think of that. Thank you! I really appreciate your help. Share this post Link to post Share on other sites
