bonkingbilly 0 Posted January 9, 2018 hi guy hope someone can help before I pull all my hair out I have a pcut cs630 and I'm using flexi 10 software after installing this on a windows 10 computer every time I send to plotter the carriage shoots to the left until it hits the cut out switch. I have checked baud rate is 38400 and its running on com 3 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 9, 2018 Are you absolutely certain the 38400 is the correct baud rate? I have not had my P-Cut for several years but that seems off. 1 Share this post Link to post Share on other sites
mb20music 760 Posted January 9, 2018 42 minutes ago, Wildgoose said: Are you absolutely certain the 38400 is the correct baud rate? I have not had my P-Cut for several years but that seems off. Should be 9600, I do believe 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 10, 2018 9600 sounds correct. Share this post Link to post Share on other sites
bonkingbilly 0 Posted January 10, 2018 hi guys changed it to 9600 in flexi and com settings now it just says on the cutter "working com-connection" when I send but no movement from the head Share this post Link to post Share on other sites
TheCuttingGuy 0 Posted March 29, 2018 On 10/01/2018 at 6:41 PM, bonkingbilly said: hi guys changed it to 9600 in flexi and com settings now it just says on the cutter "working com-connection" when I send but no movement from the head bonkingbilly did you ever get this sorted out? I have the exact same problem with the 'working com-1 Connection'. Share this post Link to post Share on other sites
