Problems with Roland and length/width
I'm not sure how to even explain this.
My Roland's carriage is on the left so I have it set to 0 degrees.
When I try to import a cut file over 24" LONG it won't let me cut it because it thinks my vinyl is only 24" long and 100" wide when it's the other way.
However, I can't manually swap those numbers because it won't let me make the "width" (y) larger than 47".
All of my designs are limited to 47" long which is not an option for me.
Any suggestions?
If I rotate the image, it gets a red X through it and I can't cut it.
Edit: I read another post and realized there was an option tucked up here.
