Dakes2 2 Posted July 17, 2017 I have Liyu SC 631 E cutter and having some issues with cutting with signcut, its not cutting a perfect path on the vinyl, to try and explain better lets say I try to cut a letter O, whats happening is the circle is not joining up and I am having to use a blade to complete the O, this is mainly happening with circles and oblongs, I'm not sure if this is a signcut problem or a cutter problem, I have calibrated the cutter, the problem is only slight but its leaving small tags attached and makes weeding difficult, any help on this much appreciated Not very good at freehand drawing but basically this is what I'm getting. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 17, 2017 See if Signcut has an overcut feature. Add a little to the overcut. Share this post Link to post Share on other sites
