MPaguagaJr 1 Posted June 27, 2016 I have a laser point II and want to make some stencils. What kind of thick paper can and do you recommend I use? Also which blade do I use for cutting? Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted June 27, 2016 Card stock is always good for painting stencils if it's for etching use vinyl I have used Oracal 651 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 27, 2016 I have also used leftover carrier sheets from vinyl jobs. (the clear carrier from Gerber 225 is awesome in this application but harder to come by). Either way you will need a sticky carrier to go under your stencil in order to cut though it and not have it come apart on you. I have a cricut cutting mat from walmart and also often use a piece of clear app tape turned upside down. Share this post Link to post Share on other sites
