bradqr1954 6 Posted June 22, 2015 I have a CE-6000-40. When I send a file it will only cut 6 feet. So if a file is 9 feet long it only cuts 6 feet of it. Any ideas? Thanks in advance Brad Share this post Link to post Share on other sites
Command 97 Posted June 22, 2015 Sounds more like your cutting software is limiting the cutter? Did you check your settings? Share this post Link to post Share on other sites
bradqr1954 6 Posted June 22, 2015 I am using Cutting Master 3 out of Illustrator CS6. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 22, 2015 I just took a quick look at it, but make your page size is bigger than your design..... Share this post Link to post Share on other sites
bradqr1954 6 Posted June 22, 2015 I'll give it a try Share this post Link to post Share on other sites
arty-rc 719 Posted June 23, 2015 Check your settings on the cutter control panel. You can set the length of the vinyl on a Graphtec. Share this post Link to post Share on other sites
bradqr1954 6 Posted June 25, 2015 Thanks Arty. I think that was the answer. And a good thing. I have a big job coming up. Brad Share this post Link to post Share on other sites
brilliantdesigns 0 Posted July 20, 2015 how do you set the length of vinyl on the graphtec menu? Where do i go? please help having issues Share this post Link to post Share on other sites
