nylebuss 0 Posted June 27, 2012 I'm trying to use SignCut with the Keyspan adapter in Mac OS X Lion, I have installed the latest FTDI and Keyspan drivers that I can find, with my Copam CP-2500 but when I try to send a file to the cutter I just get the dialog that SignCut is sending the file with an unknown amount of time remaining and then it never moves. Any clue on how I might get this working? I did have it working through USB but I accidentally tripped over the USB cord and broke the USB port on the Cutter, and I'd really like to not have to spend $80 on a new motherboard since I have all the pieces for this to work via the Keyspan, technically at least. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 27, 2012 I don't use a Mac, but have you worked thru all the steps here? Choose your cutter and work thru the info.. Check and double check, If this doesn't work, put in a support ticket to USCUTTER, and see if they can remote you... http://start.uscutter.com/ Share this post Link to post Share on other sites
nylebuss 0 Posted June 27, 2012 Yes, I have. Though I don't have the option of using /dev/cu.usbserial-000012FD, the only options I have are the two that are listed in the pictures. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 27, 2012 Better just to have tech support check it out, Give them a call. 425-902-1302 Or put in a support ticket http://support.uscutter.com/index.php?/Tickets/Submit Share this post Link to post Share on other sites
nylebuss 0 Posted June 27, 2012 Got in touch with them, turns out I, unfortunately, must have broke the Serial port when I broke the USB port, but fortunately I'm still covered by the warranty so I just need to replace the motherboard. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 27, 2012 Got in touch with them, turns out I, unfortunately, must have broke the Serial port when I broke the USB port, but fortunately I'm still covered by the warranty so I just need to replace the motherboard. Great... glad your getting some where.... Share this post Link to post Share on other sites
