harley222 0 Posted August 26, 2011 Ok folks, im having a issue with my cutter, its not finishing the lines on cuts. I had to draw it out cuz i couldnt get a clear pic of what im talking about but here it is.... Share this post Link to post Share on other sites
harley222 0 Posted August 26, 2011 an idea what i should set it at? its at .0098 right now.. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 27, 2011 an idea what i should set it at? its at .0098 right now.. it depends on which software your using, Signblazer or any this is mm is approx .25mm .... Share this post Link to post Share on other sites
harley222 0 Posted August 27, 2011 im using signcut it depends on which software your using, Signblazer or any this is mm is approx .25mm .... Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 27, 2011 im using signcut doesn't Signcut have a choice of mm AND inches? Share this post Link to post Share on other sites
harley222 0 Posted August 27, 2011 yea but when i changed it to mm it said .25 so its on. what do i set it to and why did it change all of a sudden? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 27, 2011 yea but when i changed it to mm it said .25 so its on. what do i set it to and why did it change all of a sudden? then use it there on mm .25, do some test cuts and see if it is where it should be.. Share this post Link to post Share on other sites
fatewilleatyou 3 Posted August 31, 2011 Based on your photo, I'd say that your vinyl is slipping, make sure it's staying under the pinch rollers, and make sure they're tight enough for the medium that you're cutting. Share this post Link to post Share on other sites
harley222 0 Posted September 1, 2011 thanks im gunna check into that cuz i never changed the offset and it just started doing this so im thinking that might be the case Share this post Link to post Share on other sites
harley222 0 Posted September 5, 2011 Well i up'ed the offset 1 click and it fixed it. Weird cuz i never messed with it to change but its fixed, and thanks for all your guys imput....thanks again.. Share this post Link to post Share on other sites
