verdeisthebest 0 Posted June 21, 2011 Hi I need to buy a printer, dont need to be big it can be like 20 inch. I just need recomendations I preffer that the printer have contour system. NEED HELP ASP Share this post Link to post Share on other sites
jfought 120 Posted June 21, 2011 depends on what you are going to do with it. look a a roland versacamm sp300. it ia 30" printer cutter. in the mean time i offer wholesale printing to the forum. just let me know what i can do to help. i have 54" versacamm. 1 Share this post Link to post Share on other sites
stetson5331 80 Posted June 21, 2011 Hi I need to buy a printer, dont need to be big it can be like 20 inch. I just need recomendations I preffer that the printer have contour system. NEED HELP ASP Hi, My best advice is that you buy the best you can afford..I like Mutoh it's a top of the line..There are others that will certainly work for your needs...I am just partial to the Mutoh... As for the contour feature..The printer does not do anything with a contour..It does just what it states is print..the cutter and your software will need to be what has the contour features...If the software puts the reg marks for the contour and the cutter reads the marks be it by manually lining up the marks or if you have a cutter that will automatically read the marks like a Graphtec then it will contour cut... I suggest a Graphtec also top of the line which has the A.R.M.S. feature(automatic registration mark sensor)...But there are certainly more out there that have a manual laser for contour cutting opr alignment..Again I am partial the Graphtec..I am also partial to Flexi Pro which has the contour feature available in it as well.. There are different ways to do contour cutting as I am sure others will chime in...I hope this helps.. stetson5331 1 Share this post Link to post Share on other sites
verdeisthebest 0 Posted June 21, 2011 Hi thanks guys, Im looking more like a type of desktop printer and the budget is like a $6,000.00 Share this post Link to post Share on other sites
jfought 120 Posted June 21, 2011 what type of print do you want to do with it? Share this post Link to post Share on other sites
verdeisthebest 0 Posted June 22, 2011 print tshirt transfers then cut it out on a plotter Share this post Link to post Share on other sites
jfought 120 Posted June 22, 2011 workforce 1100 from cobra inks is what you need Share this post Link to post Share on other sites
verdeisthebest 0 Posted June 23, 2011 do you know how much cost the ink cart. of that epsonworkforce Share this post Link to post Share on other sites
hockeygirl 30 Posted June 24, 2011 You'll find all the info you need here: http://cobraink.com/epson1100.htm Share this post Link to post Share on other sites
