421banshee 0 Posted March 18, 2011 hi guys i am new here i just bought a pcut 630 to cut decals for our local truck club and when ever i try to cut something the ting will cut like two seconds then it hits the red button on the left side and stops it i can not figure out how to correct this. i shut it off then move it over start it up and it hits it again.... Share this post Link to post Share on other sites
AshComputers 197 Posted March 18, 2011 Ok, what program are you using to cut with? Next, check your output sizes in your cutting software. Next, when you start up your machine and have everything in place, push your reset button to set it. Sounds more like the reset button needs to be pushed. Make sure you push it before each cut. Mine works well this way. Let us know if this helps. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 18, 2011 hi guys i am new here i just bought a pcut 630 to cut decals for our local truck club and when ever i try to cut something the ting will cut like two seconds then it hits the red button on the left side and stops it i can not figure out how to correct this. i shut it off then move it over start it up and it hits it again.... you need to hit the ORIGIN button,, then that will be your starting point Share this post Link to post Share on other sites
AshComputers 197 Posted March 18, 2011 Ok, what program are you using to cut with? Next, check your output sizes in your cutting software. Next, when you start up your machine and have everything in place, push your reset button to set it. Sounds more like the reset button needs to be pushed. Make sure you push it before each cut. Mine works well this way. Let us know if this helps. Sorry, I mean the origin/reset button hehehe Tanks Skeet Share this post Link to post Share on other sites
