remus 5 Posted October 22, 2010 Hi...Long story made short, I have a copam 2500, it is about 3 years old i guess. I went to cut this design ( it's attached) & it cut everything perfect other then the outline of Texas ( i have used this outline numerous times before) so i figured it might have been corrupted, so i made another eps of the outline of Texas. Then sent the whole job to the plotter & this time it cut out the outline perfect, but then skipped other parts of the design that it cut perfect before. I think my plotter is losing steps, so can someone please try & cut this out, so i can see if it's my plotter....Also the plotter has been making noise for awhile now. Thanks for anyone who attempts this, i appreciate it. texas-911-sign.eps texas-911-sign.eps Share this post Link to post Share on other sites
remus 5 Posted October 23, 2010 My file has been downloaded 5 times & no one has reported back if they can cut it or not....Come on now help a brother out, i have a ton of work that i need to get done & need to know if i need to be shopping for a new plotter..... Share this post Link to post Share on other sites
tekcorps 50 Posted October 23, 2010 I didn't cut it, but the file looked fine to me. Maybe someone else looked and can confirm. GL Share this post Link to post Share on other sites
mr300s 1,272 Posted October 23, 2010 I didn't cut it, but the file looked fine to me. Maybe someone else looked and can confirm. GL Not to me look at it in wire frame there is a couple of blank layers on top and the letters are messed up needs clean up??? Share this post Link to post Share on other sites
remus 5 Posted October 23, 2010 Thanks for the input, I will look at the file in wireframe & check it out, but the letters cut perfect....the problem has been either the outline not cutting & everything else cuts fine, or the outline cuts fine & the pistol & bullet holes miss sections when cutting.... Share this post Link to post Share on other sites
remus 5 Posted October 23, 2010 I looked at it in wireframe & i see nothing that would keep it from cutting, maybe i am overlooking something....I need to figure this out this soon, to see if i need to buy another plotter for next week.... Will plotters drop info or lose some steps in cutting? & if so whats the cause? Share this post Link to post Share on other sites
mr300s 1,272 Posted October 23, 2010 I looked at it in wireframe & i see nothing that would keep it from cutting, maybe i am overlooking something....I need to figure this out this soon, to see if i need to buy another plotter for next week.... Will plotters drop info or lose some steps in cutting? & if so whats the cause? I still see it messed up in wire frame?? Maybe I am looking at something wrong and I just tried to cut it and it will not cut??? Share this post Link to post Share on other sites
mr300s 1,272 Posted October 23, 2010 See if you can cut this one?? texas7.EPS texas7.EPS Share this post Link to post Share on other sites
remus 5 Posted October 23, 2010 mr300 - thanks i will see if that one cuts here in a little while & i will let you know the outcome. Share this post Link to post Share on other sites
mr300s 1,272 Posted October 23, 2010 mr300 - thanks i will see if that one cuts here in a little while & i will let you know the outcome. NP I just fixed a small node edit so you might want to download this last one I will try and cut it also Share this post Link to post Share on other sites
mr300s 1,272 Posted October 23, 2010 No problem on my end cut great?? Share this post Link to post Share on other sites
