DJSirr 0 Posted July 10, 2010 Newbie question in SignBlazer- I have a fairly big job laid out, but want to cut it first on a smaller piece of vinyl to check it out first. Any way I can just do this in the cutting process? Thanks everyone! Share this post Link to post Share on other sites
Buggie Pilot 4 Posted July 10, 2010 I would just save the original file. Then select all, then resize it in the lower tool bar. Then you can cut it to see if it all works. or as an option I use often, try the pen and paper route. Then if it all works just open the original file again and cut away Good Luck Pete G Share this post Link to post Share on other sites
