MaDeucePaint 0 Posted June 29, 2010 Ok, I have a Star that is cutting twice and have no idea why. I have checked my fill and also if I have 2 images but no luck. I used the search button and thought I had this all taken care of but tried it again and no luck, maybe the pros here can let me know what I am doing wrong star double cut.eps star double cut.eps Share this post Link to post Share on other sites
mr300s 1,272 Posted June 29, 2010 Sounds like there is two layers try holding the mouse down and sliding one layer over or go to view and look at it in wire frame and see f you can see anything? 1 Share this post Link to post Share on other sites
tinaski 11 Posted June 29, 2010 Agree I think inkscape has a sticky cutting many times Share this post Link to post Share on other sites
hockeygirl 30 Posted June 30, 2010 Sounds like AI is tracing the black AND white. An easy solution is when you go to cut, just cut the black. Otherwise, in AI, ungroup, from pathfinder, outline, ungroup again, ignore overlap in pathfinder (this is purely from memory, so I could be off). Share this post Link to post Share on other sites
cutter-nutter 0 Posted March 12, 2011 I have had a similar thing happen. My file is a simple outline of a star, like so: ☆. The cutting head goes over the outline twice for some season. I have checked in Ai and the art is one single vector with a 1 point stoke. There is absolutely nothing else in the file. I've also searched and found various people with this same problem, but no concrete solutions mentioned other than checking the artwork for extra lines. Anyone have any ideas why this is happening? Edit: I'm using the US Cutter MH871 with the included SIgnBlazer program. Share this post Link to post Share on other sites
MrMopar64 47 Posted March 12, 2011 Not sure what cutter or program your using but in the cut window there is a setting for how many passes you want the cutter to make I think it's under the advanced tab MM64 Share this post Link to post Share on other sites
cutter-nutter 0 Posted March 13, 2011 I'm using the US Cutter MH871 with the included SIgnBlazer program. I'm a real newb with cutters, but experienced with line art and Ai. I was hoping there might be a setting like the one you mentioned. I will take a closer look next time. Thank you MrMopar64! Share this post Link to post Share on other sites
MrMopar64 47 Posted March 13, 2011 I'm using the US Cutter MH871 with the included SIgnBlazer program. I'm a real newb with cutters, but experienced with line art and Ai. I was hoping there might be a setting like the one you mentioned. I will take a closer look next time. Thank you MrMopar64! The only thing I can find in Sign Blazer that MIGHT cause this would be the Duplicate Position under Perferances MM64 Share this post Link to post Share on other sites
cutter-nutter 0 Posted March 13, 2011 The only thing I can find in Sign Blazer that MIGHT cause this would be the Duplicate Position under Perferances MM64 Yes, um, under Settings>Preferences I see a section called "Duplicate Position". There is no checkmark to un-check, only the heading and two numerical text fields marked "vertical" and "horizontal" under-which .08 is entered. I suppose this may be what you're referring to? And it seems it may well be the culprit. Since I can't uncheck the preference like I would expect, I will enter 0 and see if that gets rid of the the second pass. Share this post Link to post Share on other sites
MrMopar64 47 Posted March 13, 2011 Yes, um, under Settings>Preferences I see a section called "Duplicate Position". There is no checkmark to un-check, only the heading and two numerical text for "vertical" and "horizontal" under-which .08 is entered. I suppose this may be what you're referring to? And it seems it may well be the culprit. Since I can't uncheck the preference like I would expect, I will enter 0 and see if that gets rid of the the second pass. Yeah the way I understood it was that if you set it to 0 it would still go around twice but cut the same line MM64 Share this post Link to post Share on other sites
cutter-nutter 0 Posted March 13, 2011 Yeah the way I understood it was that if you set it to 0 it would still go around twice but cut the same line MM64 OK, huh, there doesn't seem to be an option to turn it off. Just a couple of fields for the offset. Weird. I do have a thin stroke in the Ai file, with about a 1point thickness, just so I can see it. You don't suppose that it would cut both edges of the stroke width do you. It's just one line. Share this post Link to post Share on other sites
MrMopar64 47 Posted March 13, 2011 OK, huh, there doesn't seem to be an option to turn it off. Just a couple of fields for the offset. Weird. I do have a thin stroke in the Ai file, with about a 1point thickness, just so I can see it. You don't suppose that it would cut both edges of the stroke width do you. It's just one line. I can't say for sure but I think it could... just remove it and give it a try MM64 Share this post Link to post Share on other sites
cutter-nutter 0 Posted March 13, 2011 Do you think weeding options could have something to do with it? Share this post Link to post Share on other sites
boosted 2 Posted March 13, 2011 Do you think weeding options could have something to do with it? post the file here and have someone look at it. the duplicate option you are messing with has nothing to do with it. it is for when you duplicate an object on the screen it places it off to the side instead of directly on top of the copied object. Share this post Link to post Share on other sites
airconguru 0 Posted May 5, 2011 You have a duplicate on the outer part of the star. I ungrouped the image and used the direct select tool on the outer edge and deleted it. Looks like that's all you have to do. Share this post Link to post Share on other sites
hockeygirl 30 Posted May 5, 2011 if your design was traced using Live trace is Illy, it'll trace both black and white, you'll just have to delete one, or select only to cut the black. Share this post Link to post Share on other sites
kyjeeper 1 Posted May 5, 2011 if your design was traced using Live trace is Illy, it'll trace both black and white, you'll just have to delete one, or select only to cut the black. Best way around this is to use the "simple trace" or "one color logo" preset in the live trace tool bar. Will only trace the black, acting as if the white is transparent. 1 Share this post Link to post Share on other sites
