Cuttter 1 Posted May 25, 2010 I have been trying to print from inkscape over and over again my problom is the size I am trying to print is 11x17, each time it prints an 8.5x11, no matter if I change the document size to 11x17 manually or even choose the correct setting in the printer setup. If any one has had this issue and corrected it, please let me know what you did to correct it. Share this post Link to post Share on other sites
mr300s 1,272 Posted May 25, 2010 I have been trying to print from inkscape over and over again my problom is the size I am trying to print is 11x17, each time it prints an 8.5x11, no matter if I change the document size to 11x17 manually or even choose the correct setting in the printer setup. If any one has had this issue and corrected it, please let me know what you did to correct it. Never tried it because it's so easy in Sign Blazer why not give that a try? Share this post Link to post Share on other sites
JoeCamaro 11 Posted May 25, 2010 You changed the setting in Inkscape to 11" x 17", BUT did you change the setting in the print dialog box? Check that out. Maybe it is set to print in 8.5" x 11" which is the standard. Share this post Link to post Share on other sites
Cuttter 1 Posted May 29, 2010 It is Windows, I did also change both to 11x17 and also tried tabloid setting. Share this post Link to post Share on other sites
Cuttter 1 Posted May 29, 2010 I have been trying to print from inkscape over and over again my problom is the size I am trying to print is 11x17, each time it prints an 8.5x11, no matter if I change the document size to 11x17 manually or even choose the correct setting in the printer setup. If any one has had this issue and corrected it, please let me know what you did to correct it. Never tried it because it's so easy in Sign Blazer why not give that a try? I will give it a try. Share this post Link to post Share on other sites
mr300s 1,272 Posted May 30, 2010 I have been trying to print from inkscape over and over again my problom is the size I am trying to print is 11x17, each time it prints an 8.5x11, no matter if I change the document size to 11x17 manually or even choose the correct setting in the printer setup. If any one has had this issue and corrected it, please let me know what you did to correct it. Never tried it because it's so easy in Sign Blazer why not give that a try? I will give it a try. If you need anymore help let me know Share this post Link to post Share on other sites
Cuttter 1 Posted May 30, 2010 I have been trying to print from inkscape over and over again my problom is the size I am trying to print is 11x17, each time it prints an 8.5x11, no matter if I change the document size to 11x17 manually or even choose the correct setting in the printer setup. If any one has had this issue and corrected it, please let me know what you did to correct it. Never tried it because it's so easy in Sign Blazer why not give that a try? I will give it a try. If you need anymore help let me know That didn't work either, the image is sqewed with lines across the entire image. I have posted an image. Share this post Link to post Share on other sites
