ollitrop
PCUT leaves a TINY uncut section on all cuts
PCUT leaves a TINY uncut section on all cuts.
So when I am trying to weed something that is small or thin it ends up getting ruined.
Is there a way to ensure it cuts all the way thru a line and doesnt skip a TINY section? Its annoying and a waste of Vinyl.
Any suggestions?
Guest fivestar
sounds like knife offset needs adjusted.  What software you running and people on here can tell you how to adjust it.  I only use flexi so if you are not running that then I cannot help you.
Its not only PCUT, I have a MH721 and a MH365 Refine they both leave that small uncut area. I have changed the cutter offset, the overcut , cutting speed, and cutter, nothing helps. This is real bad on small cut. I wish some one will have a fix. I am using AI and signcut,  HELP PLEASE ;D:huh:
ollitrop and bigmac,
This is almost certainly a knife offset issue.  Try doubling the knife offset and see what the result is (it should overcut at this point).
