castironrobbie 30 Posted October 28, 2015 I am having extreme troubles with applying to walls. I just made the attached and tried to apply it to my wall just as a practice and it peeled right off with the tape. I am using the Oracal 631 and HT55 tape. I go over the tape a ton to make sure I have all the air bubbles out, but is there a such thing as too much? Really getting frustrated. Since I got into vinyl it's really not been my thing. Share this post Link to post Share on other sites
bradqr1954 6 Posted October 28, 2015 What kind of paint is on the wall? Share this post Link to post Share on other sites
castironrobbie 30 Posted October 28, 2015 Edit: Looks to be satin or eggshell Share this post Link to post Share on other sites
dcbevins 340 Posted October 28, 2015 If it is a rough surface it can be hard to get it to adhere. If the paint has Teflon, stain guard, or other anti-stain formulation, it can also be hard. The walls in my work space are painted plywood. They are a pure bear to practice on. I have to use low tact tape that barely lifts the vinyl. I have to squeegee, tennis ball, and peel inch by inch. Share this post Link to post Share on other sites
KYSIGN 233 Posted October 28, 2015 You need to peel the application tape off at 180° angle. You will be peeling it back onto itself. To clarify the nonsticky side will be touching the nonsticky side as you peel. If you pull it outward the hightack tape can pull up the lowtack 631 vinyl. If you still have problems then it could be the paint or surface prep. I recommend cleaning the wall with a soft dry cloth first. You just need to remove dirt and oils. If the walls are sticky you probably have cigarette smoke buildup and will need to use an appropriate cleaner and allow to dry throughly. Don't install on freshly painted surfaces. 1 Share this post Link to post Share on other sites
skener 11 Posted October 28, 2015 I know how you feel when I first tried one it was the same , like previous have said could be the surface, go slow and keep trying I'm sure you will get there in the end. Good Luck! Share this post Link to post Share on other sites
