jmoney 0 Posted April 9, 2008 When you have a file that you vectorize and there are some things you need to take out or color in how do you do that I cannot figure it out. Share this post Link to post Share on other sites
firemalt 10 Posted April 9, 2008 In SignBlazer... you can select/highlight the image, then click on the "node edit" button to change the image. Share this post Link to post Share on other sites
Jay2703 704 Posted April 9, 2008 You can do an Arrange + Split Objects if they are not connected. It will allow you to delete individual peices. If it is part of an element you can try Node Edit. and erase individual nodes of select a rectangle around a bunch of nodes to delete. Once you split your objects they can be colored individually. Share this post Link to post Share on other sites
