HHeaglepub 0 Posted March 30, 2008 I created the attached in AI and I am getting a double cut around each line in the lettering and inside the weights. How do I the lines to only cut once and not double cut? The lines are currently a 1pt line is there some other way I should be doing this? Thanks in advance! Stand jacket Logo.eps Stand jacket Logo.eps Share this post Link to post Share on other sites
fourthsyde 0 Posted March 30, 2008 try this one purplemonkeydishwasher.eps purplemonkeydishwasher.eps Share this post Link to post Share on other sites
HHeaglepub 0 Posted March 30, 2008 Thanks fourthsyde - did you just re-trace? Any idea how I keep the lines from cutting twice on my initial layout in AI or do I just need to do a trace after I'm done? Share this post Link to post Share on other sites
fourthsyde 0 Posted March 30, 2008 there was a stroke around everything that had to be removed, not sure how it was drawn, but it was easy to fix once i identified the problem... Share this post Link to post Share on other sites
HHeaglepub 0 Posted March 30, 2008 Thank you for your help! Share this post Link to post Share on other sites
