2001kx 0 Posted January 27, 2014 i use corel draw x5 to cut my decals. the issue i have is when i create a decal for example: then i add cut lines with the 2 point line tool in corel draw..just to make it easier for me to weed. i then combine it all. if i cut it now it will work fine but as soon as i export it as .eps file and re-load it into corel draw to cut it will double cut the lines that i added with the 2 point line tool (it cuts up and back on the same line) any way i can do this without having it double-cut the lines that i add after i save the file? Share this post Link to post Share on other sites
