jmoney 0 Posted February 19, 2008 After I make a cut and am going to do the next it sucks the vinyl out of machine how do I adjust this to where it will not do that. Thanks for any help Share this post Link to post Share on other sites
JoeCamaro 11 Posted February 19, 2008 You have to set the origin point of the cut, there is a button for that in the panel. You have to make sure Plotter is calibrated, if you are using sign cut go to Settings>Cutter>Calibrate Cutter> cut the square, measure it and put the digits in the spaces. Make sure you artwork fits in the vinyl provided. If you are cutting a huge decal it will start somewhere far from the origin. JOe Share this post Link to post Share on other sites
Jay2703 704 Posted February 19, 2008 If you are using SignBlazer there is a setting to advance your material after cutting. Look in the Cutter panel under setup. Share this post Link to post Share on other sites
