theishkid 13 Posted April 9, 2011 Hello all. I'm about to do my first install next week and I want to get all the fluids I might need... Cleaners/Application fluids. For cleaning I've been told to use rubbing/isopropanol alcohol. But is that all you use for cleaning the glass? Or do you use a glass cleaner without ammonia first and then use the alcohol? And what about for paint on a car? Is it safe to use alcohol on a car paint? For Application fluid I've read on here to mix a gallon 3/4 full of water, 3 or 4 squirts of liquid dish soap, and then fill the rest with more alcohol. Is that right? Is there anything else I need to know? Any special kind of dish soap? Share this post Link to post Share on other sites
boosted 2 Posted April 9, 2011 Hello all. I'm about to do my first install next week and I want to get all the fluids I might need... Cleaners/Application fluids. For cleaning I've been told to use rubbing/isopropanol alcohol. But is that all you use for cleaning the glass? Or do you use a glass cleaner without ammonia first and then use the alcohol? And what about for paint on a car? Is it safe to use alcohol on a car paint? For Application fluid I've read on here to mix a gallon 3/4 full of water, 3 or 4 squirts of liquid dish soap, and then fill the rest with more alcohol. Is that right? Is there anything else I need to know? Any special kind of dish soap? I use the Iso on both surfaces. AS far as the homemade app juice, I believe you only want a couple of drops of soap not squirts. Share this post Link to post Share on other sites
