xxwckdxx 0 Posted March 11, 2011 Its made in photoshop, all of the objects are custom shapes. Can someone give me a detail how to convert this to be able to be plotted? New to all this, file attached is a jpg since the psd is so big. Thanks Share this post Link to post Share on other sites
Stlouistech 2 Posted March 11, 2011 Its made in photoshop, all of the objects are custom shapes. Can someone give me a detail how to convert this to be able to be plotted? New to all this, file attached is a jpg since the psd is so big. Thanks In Photoshop you should have the option to save as or export....try exporting it or saving it as an EPS file. If you need help send me the PSD in an email. Share this post Link to post Share on other sites
xxwckdxx 0 Posted March 11, 2011 In Photoshop you should have the option to save as or export....try exporting it or saving it as an EPS file. If you need help send me the PSD in an email. I did that then I opened it in sign blazer and it doesn't recognize the shapes. I opened it in illustrator then and used live trace, which made all the work paths but then I saved it and its blank in Signblazer? Any suggestions? Maybe I will let you convert it for me and Ill look over it after...what's your email want to pm it to me? Share this post Link to post Share on other sites
Connor 3 Posted March 11, 2011 i use corel draw x5 and created an .eps file for you. sorry i cant explain how to do it for yourself. dog bones.eps Share this post Link to post Share on other sites
hockeygirl 30 Posted March 11, 2011 You'll need to open it in Illustrator and create the vectors for it. Share this post Link to post Share on other sites
xxwckdxx 0 Posted March 11, 2011 You'll need to open it in Illustrator and create the vectors for it. Export paths to Illustrator Then open in illustrator, live trace it and export as eps? Share this post Link to post Share on other sites
