stevelucky 0 Posted June 29, 2010 I have the Copam CP-2500 running on a Mac using Illustrator exporting to SignCut Pro. Everything is working great except it seems that the unusable border that the Copam leaves as a "buffer" zone is excessive. I lose an inch to an inch and a half along each edge. Is there a way to adjust it so that the cutter cuts a littl closer to the edge, say 1/2". If I'm losing an inch on each side that's 2 inches total which seems a bit much to me. Any ideas? Share this post Link to post Share on other sites
YadirellT 0 Posted July 8, 2010 The Copam measures the paper by using the pinch rollers set on either side of the material. To adjust this, try moving the pinch rollers further out to the edge of the material. If you have a Copam with 3 rollers, use the 2 outside pinch rollers. Share this post Link to post Share on other sites
