prettybird 0 Posted December 9, 2009 Hi, I am using mostly the Oracal 631 matte vinyl and someone on here suggested using US Cutter brand clear transfer tape for it. Well that works much better than what I was using except I was wondering if that is what is recommended for the 631 metallic colors? It doesn't seem to stick as good to the metallic. Has anyone else had that problem too? Should I use a different kind for the 631 metallic? Thanks! Share this post Link to post Share on other sites
butnz 0 Posted December 10, 2009 Try some of the high tack tape http://www.uscutter.com/RTape-ApliTape-4075--High-tack-General-Purpose-Application-Tape-100yd_p_143.html I used some of the clear tape on 651 regular vinyl, but the 4075 works better. Share this post Link to post Share on other sites
