MVarzoni 0 Posted December 7, 2009 Hello Folks! I need help writing a text on vertical the word is PERFUMARIA (perfum store in portuguese...) But if I hit enter the space between each line will be 15centimeters, I would need it to be 5 centimeters only. If I make eache letter individual, I simply can't align them... Is there any hint to fix that? Thanks Mauricio Share this post Link to post Share on other sites
mr300s 1,272 Posted December 7, 2009 Hello Folks! I need help writing a text on vertical the word is PERFUMARIA (perfum store in portuguese...) But if I hit enter the space between each line will be 15centimeters, I would need it to be 5 centimeters only. If I make eache letter individual, I simply can't align them... Is there any hint to fix that? Thanks Mauricio If your using SB just hit the node/edit button top and take the square on the bottom of the text and move it up that will bring everything closer hope thats what you are talking about Share this post Link to post Share on other sites
MVarzoni 0 Posted December 7, 2009 Yes, That is what I need. Do you know how to give same space for all letters? can I do it automaticaly? Also, I cant print anything larger than 1 meter SB simply stops at this point... and the text that i need to cut is 3 meters long. Any Idea? Thank you! Mauricio Share this post Link to post Share on other sites
Jay2703 704 Posted December 7, 2009 Doing what mr300 said will keep the text equally spaced. As for you cutting legth, what is your material size set to in the cut window? Jay Share this post Link to post Share on other sites
vicentillo29 0 Posted December 12, 2009 USE A SMALL RECTANGLE TO SPACE THE LETTERS AND ALSO A LONG RECTANGLE TO LINE THEM UP DOING THE NODE EDIT OPCION Share this post Link to post Share on other sites
