jgreen
PCut play in the blade holder assembly
I was recently reading about an adjustment (in the LP discussion section) to remove the horizontal back to front play from the blade holder.  This tip also works for the PCut as I had previously stumbled onto this same discovery.  However, I have yet to discover any way of taking out the left to right play in the blade holder assembly.  My machine has been in use for better than 5 years now and is begining to show its age (especially in the amount of left to right play).  In fact, it seems to be causing blade chatter when the carriage makes a straight cut from left to right.  Right to left cuts are no problem.  Has anyone been able to make an adjustment to fix this issue?
