Guest JogaShop Posted July 29, 2009 I need the white background taken off of this graphic please... Share this post Link to post Share on other sites
firemalt 10 Posted July 29, 2009 I used a combination of Inkscape and Flexi Pro, so if you are using SBE, it probably won't open, so maybe you use the jpg or the ai file. drawing.ai drawing.eps drawing.ai drawing.eps Share this post Link to post Share on other sites
Guest JogaShop Posted July 29, 2009 The white background is still there i just need the silhouette's or if you can make the background light blue instead of white and the girl make white and the guy leave black, thanks for trying tho Share this post Link to post Share on other sites
firemalt 10 Posted July 29, 2009 It's always going to be there in a jpg image... did you check to see if either of the files worked for you? There is no background in the ai and eps file. Share this post Link to post Share on other sites
