Yones12 1 Posted June 5, 2009 Ok i have a refine mh 871 (34 inch) i am currently running flexisign PRO 7.6, I was wondering what everyone who has this cutter set their offset to? thanks Share this post Link to post Share on other sites
tlzimmerman 11 Posted June 5, 2009 my offset it set in inches, so it is like .012 or something like that in inches, which equates to like .26 or .27 mm which is just a little more than the .25mm the blade calls for but mine cuts better there. Take your time and an intricate small graphic, and try different settings marking each one then weed them and pay attention to the cut starts and closings until you find one that weeds nicely with cuts closed perfectly, set it to that and forget it unless you mess with the blade. Each machine, and each blade depth setting is different for me, and I dial it in every time I change it. Share this post Link to post Share on other sites
Yones12 1 Posted June 6, 2009 Ok, Thanks i will try that, i think i have mine set to .23 and it works ok, i was just wondering, Share this post Link to post Share on other sites
