bombora007 0 Posted June 2, 2009 So, after I draw my design in Inkscape, then export the vector to Signblazer as an .eps file, then Signblazer will do the rest, right? Will I need to install anything off the driver disc that came with the pcut? I tried to send a design to the Pcut and instead it went to my inkjet, surely this is just a port adjustment... If anyone can add to this or even confirm what Im assuming, that would be great! Thanks! Share this post Link to post Share on other sites
Jay2703 704 Posted June 2, 2009 What connection are you using for your PCut? USB or Serial? If you are using USB you will need to install the driver. In SignBlazer to cut you use the Cut menu to cut your design. It shouldn't go to your printer. Share this post Link to post Share on other sites
bombora007 0 Posted June 2, 2009 It shooked up to usb on the front of my computer. Those drivers are on the disc that came with the cutter I assume. I thought I did that, I'll try again. Thanks! Share this post Link to post Share on other sites
Jay2703 704 Posted June 2, 2009 In SignBlazer go to the cut window then select Setup. How are your settings configured for: Cutter - S/B Creation PCut CT630 Output Device - S/B Blazer.COM1: - Communications Port Direct - S/B Checked Select "Com Settings" in the setup panel: Baud Rate - 9600 Data Bits - 8 Parity - None Stop Bits - 1 Hardware - Checked Share this post Link to post Share on other sites
